asp+XMLHTTP组件做采集常用函数收集2
2013年11月28日 11:38 本文热度 10749
'函数名:ReplaceSaveRemoteFile
'作 用:替换、保存远程图片
'参 数:ConStr ------ 要替换的字符串
'参 数:SaveTf ------ 是否保存文件,False不保存,True保存
'参 数: TistUrl------ 当前网页地址
Function ReplaceSaveRemoteFile(ConStr,strInstallDir,strChannelDir,SaveTf,TistUrl)
If ConStr="$False$" or ConStr="" or strInstallDir="" or strChannelDir="" Then
ReplaceSaveRemoteFile=ConStr
Exit Function
End If
Dim TempStr,TempStr2,TempStr3,Re,Matches,Match,Tempi,TempArray,TempArray2
Dim Start1,Start2
Set Re = New Regexp
Re.IgnoreCase = True
Re.Global = True
Re.Pattern ="<img.+?[^\>]>"
Set Matches =Re.Execute(ConStr)
For Each Match in Matches
If TempStr<>"" then
TempStr=TempStr & "$Array$" & Match.Value
Else
TempStr=Match.Value
End if
Next
If TempStr<>"" Then
TempArray=Split(TempStr,"$Array$")
TempStr=""
For Tempi=0 To Ubound(TempArray)
Re.Pattern ="src\s*=\s*.+?\.(gif|jpg|bmp|jpeg|psd|png|svg|dxf|wmf|tiff)"
Set Matches =Re.Execute(TempArray(Tempi))
If TempStr<>"" then
Else
TempStr=Match.Value
End if
Next
Next
End if
If TempStr<>"" Then
Re.Pattern ="src\s*=\s*"
TempStr=Re.Replace(TempStr,"")
End If
Set Matches=nothing
Set Re=nothing
If TempStr="" or IsNull(TempStr)=True Then
Exit function
End if
TempStr=Replace(TempStr,"""","")
TempStr=Replace(TempStr,"'","")
TempStr=Replace(TempStr," ","")
Dim RemoteFileurl,SavePath,PathTemp,DtNow,strFileName,strFileType,ArrSaveFileName,RanNum,Arr_Path
DtNow=Now()
If SaveTf=True then
SavePath=strInstallDir & strChannelDir & "/UploadFiles/" & year(DtNow) & right("0" & month(DtNow),2) & "/"
Arr_Path=Split(SavePath,"/")
PathTemp=""
For Tempi=0 To Ubound(Arr_Path)
If Tempi=0 Then
PathTemp=Arr_Path(0) & "/"
ElseIf Tempi=Ubound(Arr_Path) Then
Exit For
Else
PathTemp=PathTemp & Arr_Path(Tempi) & "/"
End If
If CheckDir(PathTemp)=False Then
If MakeNewsDir(PathTemp)=False Then
SaveTf=False
Exit For
End If
End If
Next
End If
'去掉重复图片开始
TempStr=""
If Instr(Lcase(TempStr),Lcase(TempArray(Tempi)))<1 Then
TempStr=TempStr & "$Array$" & TempArray(Tempi)
End If
Next
TempStr=Right(TempStr,Len(TempStr)-7)
'去掉重复图片结束
'转换相对图片地址开始
TempStr=""
TempStr=TempStr & "$Array$" & DefiniteUrl(TempArray(Tempi),TistUrl)
Next
TempStr=Replace(TempStr,Chr(0),"")
TempArray2=Split(TempStr,"$Array$")
TempStr=""
'转换相对图片地址结束
'图片替换/保存
Set Re = New Regexp
Re.Global = True
For Tempi=0 To Ubound(TempArray2)
RemoteFileUrl=TempArray2(Tempi)
If RemoteFileUrl<>"$False$" And SaveTf=True Then'保存图片
ArrSaveFileName = Split(RemoteFileurl,".")
strFileType=Lcase(ArrSaveFileName(Ubound(ArrSaveFileName)))'文件类型
If strFileType="asp" or strFileType="asa" or strFileType="aspx" or strFileType="cer" or strFileType="cdx" or strFileType="exe" or strFileType="rar" or strFileType="zip" then
UploadFiles=""
Exit Function
End If
Randomize
RanNum=Int(900*Rnd)+100
strFileName = year(DtNow) & right("0" & month(DtNow),2) & right("0" & day(DtNow),2) & right("0" & hour(DtNow),2) & right("0" & minute(DtNow),2) & right("0" & second(DtNow),2) & ranNum & "." & strFileType
Re.Pattern =TempArray(Tempi)
If SaveRemoteFile(SavePath & strFileName,RemoteFileUrl)=True Then
PathTemp=Replace(SavePath &strFileName,strInstallDir & strChannelDir & "/","[InstallDir_ChannelDir]")
ConStr=Re.Replace(ConStr,PathTemp)
Re.Pattern=strInstallDir & strChannelDir & "/"
UploadFiles=UploadFiles & "|" & Re.Replace(SavePath &strFileName,"")
Else
PathTemp=RemoteFileUrl
'UploadFiles=UploadFiles & "|" & RemoteFileUrl
End If
ElseIf RemoteFileurl<>"$False$" and SaveTf=False Then'不保存图片
ConStr=Re.Replace(ConStr,RemoteFileUrl)
End If
Next
Set Re=nothing
If UploadFiles<>"" Then
UploadFiles=Right(UploadFiles,Len(UploadFiles)-1)
End If
End function
'过程名:SaveRemoteFile
'作 用:保存远程的文件到本地
'参 数:LocalFileName ------ 本地文件名
'参 数:RemoteFileUrl ------ 远程文件URL
Function SaveRemoteFile(LocalFileName,RemoteFileUrl)
On error resume next
SaveRemoteFile=True
dim Ads,Retrieval,GetRemoteData
Set Retrieval = Server.CreateObject("Microsoft.XMLHTTP")
With Retrieval
.Open "Get", RemoteFileUrl, False, "", ""
.Send
If .Readystate<>4 then
SaveRemoteFile=False
Exit Function
End If
GetRemoteData = .ResponseBody
End With
Set Retrieval = Nothing
Set Ads = Server.CreateObject("Adodb.Stream")
With Ads
.Type = 1
.Open
.Write GetRemoteData
.SaveToFile server.MapPath(LocalFileName),2
.Cancel()
.Close()
End With
Set Ads=nothing
end Function
'函数名:FpHtmlEnCode
'作 用:标题过滤
'参 数:fString ------字符串
Function FpHtmlEnCode(fString)
If IsNull(fString)=False or fString<>"" or fString<>"$False$" Then
fString=nohtml(fString)
fString=FilterJS(fString)
fString = Replace(fString, CHR(9), "")
fString = Replace(fString, CHR(34), "")
fString = Replace(fString, CHR(39), "")
fString = Replace(fString, CHR(13), "")
fString = Replace(fString, CHR(10), " ")
fString=Trim(fString)
fString=dvhtmlencode(fString)
FpHtmlEnCode=fString
Else
FpHtmlEnCode="$False$"
End If
End Function
'函数名:GetPaing
'作 用:获取分页
Function GetPaing(Byval ConStr,StartStr,OverStr,IncluL,IncluR)
If ConStr="$False$" or ConStr="" or StartStr="" or OverStr="" or IsNull(ConStr)=True or IsNull(StartStr)=True or IsNull(OverStr)=True Then
GetPaing="$False$"
Exit Function
End If
Dim Start,Over,ConTemp,Erri
ConStr=LCase(ConStr)
StartStr=LCase(StartStr)
OverStr=LCase(OverStr)
Over=InstrB(1,ConStr,OverStr,vbBinaryCompare)
If Over<=0 Then
GetPaing="$False$"
Exit Function
Else
Over=Over+Lenb(OverStr)
End If
Start=Over-5
If Start<=0 Then
GetPaing="$False$"
Exit Function
End If
ConTemp=MidB(ConStr,Start,Over-Start)
Do While InstrB(1,ConTemp,StartStr,vbBinaryCompare)<=0
Erri=Erri+1
If Erri>50 then
GetPaing="$False$"
Exit Function
End If
Start=Start-5
if Start<=0 then
GetPaing="$False$"
Exit Do
Exit Function
Else
End If
Loop
Start=InstrB(1,ConTemp,StartStr,vbBinaryCompare)
If IncluL=False Then
Start=Start+LenB(StartStr)
End If
Over=InstrB(Start,ConTemp,OverStr,vbBinaryCompare)
If IncluR=True Then
Over=Over+LenB(OverStr)
End If
If Start>=Over then
GetPaing="$False$"
Exit Function
End If
GetPaing=MidB(ConTemp,Start,Over-Start)
GetPaing=Trim(GetPaing)
GetPaing=Replace(GetPaing," ","")
GetPaing=Replace(GetPaing,",","")
GetPaing=Replace(GetPaing,"'","")
GetPaing=Replace(GetPaing,"""","")
GetPaing=Replace(GetPaing,">","")
GetPaing=Replace(GetPaing,"<","")
End Function
'函数名:ScriptHtml
'作 用:过滤html标记
'参 数:ConStr ------ 要过滤的字符串
Function ScriptHtml(Byval ConStr,TagName,FType)
Dim Re
Set Re=new RegExp
Re.IgnoreCase =true
Re.Global=True
Select Case FType
Case 1
Re.Pattern="<" & TagName & "([^>])*>"
ConStr=Re.Replace(ConStr,"")
Case 2
Re.Pattern="<" & TagName & "([^>])*>.*?</" & TagName & "([^>])*>"
Case 3
Re.Pattern="</" & TagName & "([^>])*>"
End Select
ScriptHtml=ConStr
Set Re=Nothing
End Function
Function CheckDir(byval FolderPath)
dim fso
Set fso = Server.CreateObject("Scripting.FileSystemObject")
If fso.FolderExists(Server.MapPath(folderpath)) then
'存在
CheckDir = True
Else
'不存在
CheckDir = False
End if
Set fso = nothing
End Function
Function MakeNewsDir(byval foldername)
dim fso
fso.CreateFolder(Server.MapPath(foldername))
If fso.FolderExists(Server.MapPath(foldername)) Then
MakeNewsDir = True
Else
MakeNewsDir = False
End If
Set fso = nothing
End Function
'函数名:IsObjInstalled
'作 用:检查组件是否已经安装
'参 数:strClassString ----组件名
'返回值:True ----已经安装
' False ----没有安装
Function IsObjInstalled(strClassString)
On Error Resume Next
IsObjInstalled = False
Err = 0
Dim xTestObj
Set xTestObj = Server.CreateObject(strClassString)
If 0 = Err Then IsObjInstalled = True
Set xTestObj = Nothing
Err = 0
End Function
'过程名:WriteErrMsg
'作 用:显示错误提示信息
'参 数:无
sub WriteErrMsg(ErrMsg)
dim strErr
strErr=strErr & "<html><head><title>错误信息</title><meta http-equiv='Content-Type' content='text/html; charset=gb2312'>" & vbcrlf
strErr=strErr & "<link href='../admin/Admin_STYLE.CSS' rel='stylesheet' type='text/css'></head><body><br><br>" & vbcrlf
strErr=strErr & "<table cellpadding=2 cellspacing=1 border=0 width=400 align=center>" & vbcrlf
strErr=strErr & " <tr align='center' ><td height='22'><strong>错误信息</strong></td></tr>" & vbcrlf
strErr=strErr & " <tr ><td height='100' valign='top'><b>产生错误的可能原因:</b>" & ErrMsg &"</td></tr>" & vbcrlf
strErr=strErr & " <tr align='center' ><td><a href='javascript:history.go(-1)'><< 返回上一页</a></td></tr>" & vbcrlf
strErr=strErr & "</table>" & vbcrlf
strErr=strErr & "</body></html>" & vbcrlf
response.write strErr
end sub
'过程名:WriteSucced
'作 用:显示成功提示信息
'参 数:无
sub WriteSucced(ErrMsg)
dim strErr
strErr=strErr & "<html><head><title>成功信息</title><meta http-equiv='Content-Type' content='text/html; charset=gb2312'>" & vbcrlf
strErr=strErr & " <tr align='center' ><td height='22'><strong>恭喜你!</strong></td></tr>" & vbcrlf
strErr=strErr & " <tr ><td height='100' valign='top' align='center'>" & ErrMsg &"</td></tr>" & vbcrlf
'strErr=strErr & " <tr align='center' ><td><a href='javascript:history.go(-1)'><< 返回上一页</a></td></tr>" & vbcrlf
end sub
'函数名:ShowPage
'作 用:显示“上一页 下一页”等信息
'参 数:sFileName ----链接地址
' TotalNumber ----总数量
' MaxPerPage ----每页数量
' ShowTotal ----是否显示总数量
' ShowAllPages ---是否用下拉列表显示所有页面以供跳转。有某些页面不能使用,否则会出现JS错误。
' strUnit ----计数单位
'返回值:“上一页 下一页”等信息的HTML代码
function ShowPage(sFileName,TotalNumber,MaxPerPage,ShowTotal,ShowAllPages,strUnit)
dim TotalPage,strTemp,strUrl,i
if TotalNumber=0 or MaxPerPage=0 or isNull(MaxPerPage) then
ShowPage=""
exit function
end if
if totalnumber mod maxperpage=0 then
TotalPage= totalnumber \ maxperpage
else
TotalPage= totalnumber \ maxperpage+1
end if
if CurrentPage>TotalPage then CurrentPage=TotalPage
strTemp= "<table align='center'><tr><td>"
if ShowTotal=true then
strTemp=strTemp & "共 <b>" & totalnumber & "</b> " & strUnit & " "
end if
strUrl=JoinChar(sfilename)
if CurrentPage<2 then
strTemp=strTemp & "首页 上一页 "
else
strTemp=strTemp & "<a href='" & strUrl & "page=1'>首页</a> "
strTemp=strTemp & "<a href='" & strUrl & "page=" & (CurrentPage-1) & "'>上一页</a> "
end if
if CurrentPage>=TotalPage then
strTemp=strTemp & "下一页 尾页"
else
strTemp=strTemp & "<a href='" & strUrl & "page=" & (CurrentPage+1) & "'>下一页</a> "
strTemp=strTemp & "<a href='" & strUrl & "page=" & TotalPage & "'>尾页</a>"
end if
strTemp=strTemp & " 页次:<strong><font color=red>" & CurrentPage & "</font>/" & TotalPage & "</strong>页 "
strTemp=strTemp & " <b>" & maxperpage & "</b>" & strUnit & "/页"
if ShowAllPages=True then
strTemp=strTemp & " 转到第<input type='text' name='page' size='3' maxlength='5' value='" & CurrentPage & "' onKeyPress=""if (event.keyCode==13) window.location='" & strUrl & "page=" & "'+this.value;""'>页"
end if
strTemp=strTemp & "</td></tr></table>"
ShowPage=strTemp
end function
'函数名:JoinChar
'作 用:向地址中加入 ? 或 &
'参 数:strUrl ----网址
'返回值:加了 ? 或 & 的网址
function JoinChar(strUrl)
if strUrl="" then
JoinChar=""
exit function
end if
if InStr(strUrl,"?")<len(strUrl) then
if InStr(strUrl,"?")>1 then
if InStr(strUrl,"&")<len(strUrl) then
JoinChar=strUrl & "&"
else
JoinChar=strUrl
end if
else
JoinChar=strUrl & "?"
end if
else
JoinChar=strUrl
end if
end function
'函数名:CreateKeyWord
'作 用:由给定的字符串生成关键字
'参 数:Constr---要生成关键字的原字符串
'返回值:生成的关键字
Function CreateKeyWord(byval Constr)
If Constr="" or IsNull(Constr)=True or Constr="$False$" Then
CreateKeyWord="$False$"
Exit Function
End If
Constr=Replace(Constr,CHR(32),"")
Constr=Replace(Constr,CHR(9),"")
Constr=Replace(Constr," ","")
Constr=Replace(Constr,"(","")
Constr=Replace(Constr,")","")
Constr=Replace(Constr,"<","")
Constr=Replace(Constr,">","")
Dim i,ConstrTemp
For i=1 To Len(Constr)
ConstrTemp=ConstrTemp & "|" & Mid(Constr,i,2)
Next
If Len(ConstrTemp)<254 Then
Else
ConstrTemp=Left(ConstrTemp,254) & "|"
End If
CreateKeyWord=ConstrTemp
End Function
Function CheckUrl(strUrl)
Dim Re
Set Re=new RegExp
Re.IgnoreCase =true
Re.Global=True
Re.Pattern="http://([\w-]+\.)+[\w-]+(/[\w-./?%&=]*)?"
If Re.test(strUrl)=True Then
CheckUrl=strUrl
Else
CheckUrl="$False$"
End If
Set Rs=Nothing
End Function
该文章在 2013/11/28 11:38:33 编辑过
