巧用SendMessage函数扩展Treeview功能
2013年11月15日 0:19 本文热度 10282
Option Explicit
Private Type TPoint
    x As Long
    y As Long
End Type
Private Type TVHITTESTINFO
    pt As TPoint
    flags As Long
    hItem As Long
End Type
Private Type TVITEM
    mask As Long
    HTreeItem As Long
    state As Long
    stateMask As Long
    pszText As Long
    cchTextMax As Long
    iImage As Long
    iSelectedImage As Long
    cChildren As Long
    lParam As Long
End Type
Const TV_FIRST [color=#0000ff]=
&H1100
Const TVM_HITTEST = TV_FIRST + 17
Const TVM_GETITEM = TV_FIRST + 12
Const TVHT_ONITEMLABEL = &H4
Const TVIF_TEXT = &H1
Const GMEM_FIXED = &H0
'设置行高
Const TVM_SETITEMHEIGHT = TV_FIRST + 27
'设置背景色
Const TVM_SETBKCOLOR = TV_FIRST + 29
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (ByVal Destination As String, ByVal Source As Long, ByVal Length As Long)
Private Declare Function GlobalAlloc Lib "kernel32" (ByVal wFlags As Long, ByVal dwBytes As Long) As Long
Private Declare Function GlobalFree Lib "kernel32" (ByVal hMem As Long) As Long
Dim hItemPrv As Long
Private Sub Form_Load()
    Dim ndX As Node
    '加入若干Item
    Set ndX = TreeView1.Nodes.Add(, , "R", "Root", 1)
    Set ndX = TreeView1.Nodes.Add("R", tvwChild, "Key1", "Node1", 1)
    Set ndX = TreeView1.Nodes.Add("Key1", tvwChild, "SubKey1", "SubNode1", 3)
    Set ndX = TreeView1.Nodes.Add("SubKey1", tvwChild, "SubKeys1", "SubNode1", 3)
    Set ndX = TreeView1.Nodes.Add("Key1", tvwChild, "SubKey2", "SubNode2")
    Set ndX = TreeView1.Nodes.Add("Key1", tvwChild, "SubKey3", "SubNode3")
    Set ndX = TreeView1.Nodes.Add("Key1", tvwChild, "SubKey4", "SubNode4")
  '设置树型列表控件节点行(Node)高度
    Call SendMessage(TreeView1.hwnd, TVM_SETITEMHEIGHT, 30, 0)
  '设置树型列表控件的背景颜色
    Call SendMessage(TreeView1.hwnd, TVM_SETBKCOLOR, 0, RGB(255, 0, 0))
End Sub
'为树型列表控件(Treeview)中不同的节点行(Node)设置不同的Tooltips气泡提示
'在TVM类消息中有一个TVM_HITTEST消息,发送该消息可以检测控件表面上的某一点,
'如果该点位于一个标题上,则返回该标题的句柄。而利用TVM_GETITEM消息,则可以
'根据标题句柄返回该标题行的文本。所以结合利用这两个消息可以获取光标所在标题行的标题文本.
Private Sub TreeView1_MouseMove(Button As Integer, Shift As Integer, x As Single, y As Single)
    Dim ptA As TPoint
    Dim tf As TVHITTESTINFO
    Dim TV As TVITEM
    Dim hStr As Long
    Dim hItem As Long
    Dim astr As String * 1024
    Dim bstr
    On Error GoTo errLab
    '获得当前光标所在的位置坐标
    ptA.x = Int(x / Screen.TwipsPerPixelX)
    ptA.y = Int(y / Screen.TwipsPerPixelY)
    tf.pt = ptA
    tf.flags = TVHT_ONITEMLABEL
    '获得光标所在的Item的句柄
    hItem = SendMessage(TreeView1.hwnd, TVM_HITTEST, 0, tf)
    '如果未获得句柄或者同上一次是同一个Item的句柄则退出
    If ((hItem <= 0) or (hItem = hItemPrv)) Then Exit Sub
    hItemPrv = hItem
    '分配一定的内存空间用以存储Item的标题
    hStr = GlobalAlloc(GMEM_FIXED, 1024)
    If hStr > 0 Then
        TV.mask = TVIF_TEXT
        '获取标题文本
        TV.HTreeItem = hItem
        'Item句柄
        TV.pszText = hStr
        TV.cchTextMax = 1023
        '发送TVM_GETITEM获得标题文本
        Call SendMessage(TreeView1.hwnd, TVM_GETITEM, 0, TV)
        '将标题文本拷贝到字符串astr中
        CopyMemory astr, hStr, 1024
        bstr = Left$(astr, (InStr(astr, Chr$(0)) - 1))
        TreeView1.ToolTipText = bstr
        '释放分配的内存空间
        GlobalFree hStr
    End If
    Exit Sub
errLab:
    Resume Next
End Sub
该文章在 2013/11/15 0:19:06 编辑过
