C# 配置文件实战:INI 的读取、修改与删
2026年10月17日 14:25 本文热度 964
1、配置格式如下:
[Database]Server=127.0.0.1Port=3306Database=TestDB
[Camera]Exposure=100Gain=2.5AutoFocus=1
[System]LogLevel=DebugEnableLog=1
2、函数调用:
初始化:string configPath = Path.Combine(AppDomain.CurrentDomain.BaseDirectory, "SysConfig.ini");IniFileHelper config = new IniFileHelper(configPath);读取:string server = config.ReadString("Database", "Server", "127.0.0.1");int port = config.ReadInt("Database", "Port", 3306);double gain = config.ReadDouble( "Camera", "Gain", 1.0);bool autoFocus = config.ReadBool("Camera", "AutoFocus", true);写入:config.WriteString("Database", "Server", "192.168.0.12");config.WriteInt("Database", "Port", 3307);config.WriteDouble("Camera", "Gain", 2.5);config.WriteBool("Camera",  "AutoFocus", false);
3、帮助类
Windows 本身就提供了 INI 文件的读写接口,因此 C# 中不需要自己解析整个文件,可以直接通过 P/Invoke 调用系统提供的GetPrivateProfileString、WritePrivateProfileString 等函数。
public sealed class IniFileHelper{    private const int InitialBufferSize = 256;    private const int MaxBufferSize = 1024 * 1024;
    private readonly string _filePath;    private readonly object _syncRoot = new object();
    #region Windows API
    [DllImport("kernel32.dll", CharSet = CharSet.Unicode, SetLastError = true)]    private static extern uint GetPrivateProfileString(string lpAppName, string lpKeyName, string lpDefault, StringBuilder lpReturnedString, uint nSize, string lpFileName);
    [DllImport("kernel32.dll", CharSet = CharSet.Unicode, SetLastError = true)]    private static extern bool WritePrivateProfileString(string lpAppName, string lpKeyName, string lpString, string lpFileName);
    [DllImport("kernel32.dll", CharSet = CharSet.Unicode, SetLastError = true)]    private static extern uint GetPrivateProfileSectionNames(StringBuilder lpszReturnBuffer, uint nSize, string lpFileName);
    [DllImport("kernel32.dll", CharSet = CharSet.Unicode, SetLastError = true)]    private static extern uint GetPrivateProfileSection(string lpAppName, StringBuilder lpReturnedString, uint nSize, string lpFileName);
    #endregion
    public IniFileHelper(string filePath)    {        if (string.IsNullOrWhiteSpace(filePath))            throw new ArgumentException("INI 文件路径不能为空。", nameof(filePath));
        _filePath = Path.GetFullPath(filePath);
        string directory = Path.GetDirectoryName(_filePath);
        if (!string.IsNullOrEmpty(directory) && !Directory.Exists(directory))        {            Directory.CreateDirectory(directory);        }    }
    /// <summary>    /// 当前 INI 文件路径    /// </summary>    public string FilePath    {        get { return _filePath; }    }
    /// <summary>    /// 判断配置文件是否存在    /// </summary>    public bool Exists    {        get { return File.Exists(_filePath); }    }
    #region String    /// <summary>    /// 读取字符串配置。    /// </summary>    public string ReadString(string section, string key, string defaultValue = "")    {        if (string.IsNullOrEmpty(section))            throw new ArgumentException("Section 不能为空。", nameof(section));
        if (string.IsNullOrEmpty(key))            throw new ArgumentException("Key 不能为空。", nameof(key));
        lock (_syncRoot)        {            StringBuilder buffer = new StringBuilder(InitialBufferSize);
            while (true)            {                uint length = GetPrivateProfileString(section, key, defaultValue, buffer, (uint)buffer.Capacity, _filePath);
                // 返回值小于缓冲区大小,说明读取完整                if (length < buffer.Capacity - 1)                {                    return buffer.ToString();                }
                // 扩容                if (buffer.Capacity >= MaxBufferSize)                {                    return buffer.ToString();                }
                buffer.Capacity = Math.Min(buffer.Capacity * 2, MaxBufferSize);            }        }    }
    /// <summary>    /// 写入字符串配置。    /// </summary>    public void WriteString(string section, string key, string value)    {        if (string.IsNullOrEmpty(section))            throw new ArgumentException("Section 不能为空。", nameof(section));
        lock (_syncRoot)        {            bool result = WritePrivateProfileString(section, key, value ?? string.Empty, _filePath);
            if (!result)            {                throw new IOException("写入 INI 文件失败:" + _filePath);            }        }    }    #endregion
    #region Int    public int ReadInt(string section, string key, int defaultValue = 0)    {        string value = ReadString(section, key, defaultValue.ToString(CultureInfo.InvariantCulture));
        int result;
        if (int.TryParse(value, NumberStyles.Integer, CultureInfo.InvariantCulture, out result))        {            return result;        }
        return defaultValue;    }
    public void WriteInt(string section, string key, int value)    {        WriteString(section, key, value.ToString(CultureInfo.InvariantCulture));    }    #endregion
    #region Double    public double ReadDouble(string section, string key, double defaultValue = 0)    {        string value = ReadString(section, key, defaultValue.ToString(CultureInfo.InvariantCulture));
        double result;
        if (double.TryParse(value, NumberStyles.Float | NumberStyles.AllowThousands, CultureInfo.InvariantCulture, out result))        {            return result;        }
    public void WriteDouble(string section, string key, double value)    {        WriteString(section, key, value.ToString(CultureInfo.InvariantCulture));    }    #endregion
    #region Bool    public bool ReadBool(string section, string key, bool defaultValue = false)    {        string defaultText = defaultValue ? "1" : "0";
        string value = ReadString(section, key, defaultText);
        if (string.Equals(value, "true", StringComparison.OrdinalIgnoreCase))        {            return true;        }
        if (string.Equals(value, "false", StringComparison.OrdinalIgnoreCase))        {            return false;        }
        int intValue;
        if (int.TryParse(value, out intValue))        {            return intValue != 0;        }
    public void WriteBool(string section, string key, bool value)    {        WriteString(section, key, value ? "1" : "0");    }    #endregion
    #region Enum    public T ReadEnum<T>(string section, string key, T defaultValue) where T : struct    {        string value = ReadString(section, key, defaultValue.ToString());
        T result;
        if (Enum.TryParse<T>(value, true, out result))        {            return result;        }
    public void WriteEnum<T>(string section, string key, T value) where T : struct    {        WriteString(section, key, value.ToString());    }    #endregion
    #region Generic    /// <summary>    /// 根据目标类型读取配置。    /// </summary>    public T Read<T>(string section, string key, T defaultValue = default(T))    {        string value = ReadString(section, key, null);
        if (string.IsNullOrWhiteSpace(value))            return defaultValue;
        try        {            Type targetType = typeof(T);
            if (targetType == typeof(string))                return (T)(object)value;
            if (targetType == typeof(bool))            {                bool boolValue;
                if (bool.TryParse(value, out boolValue))                    return (T)(object)boolValue;
                int intValue;
                if (int.TryParse(value, out intValue))                    return (T)(object)(intValue != 0);
            if (targetType.IsEnum)            {                object enumValue;
                try                {                    enumValue = Enum.Parse(typeof(T), value, true);
                    return (T)enumValue;                }                catch                {                    return defaultValue;                }            }
            TypeConverter converter = TypeDescriptor.GetConverter(targetType);
            if (converter.CanConvertFrom(typeof(string)))            {                return (T)converter.ConvertFromInvariantString(value);            }
            return defaultValue;        }        catch        {            return defaultValue;        }    }    #endregion
    #region Section    /// <summary>    /// 获取所有 Section。    /// </summary>    public List<string> GetSections()    {        lock (_syncRoot)        {            int capacity = InitialBufferSize;
            while (capacity <= MaxBufferSize)            {                StringBuilder buffer = new StringBuilder(capacity);
                uint length = GetPrivateProfileSectionNames(buffer, (uint)capacity, _filePath);
                if (length == 0)                    return new List<string>();
                // 多字符串以 \0 分隔,最后还有一个 \0                if (length < capacity - 2)                {                    return buffer.ToString().Split(new[] { '\0' }, StringSplitOptions.RemoveEmptyEntries).ToList();                }
                capacity *= 2;            }
            return new List<string>();        }    }    #endregion
    #region Key / Value    /// <summary>    /// 获取指定 Section 下的所有配置项。    /// </summary>    public Dictionary<string, string> GetSection(string section)    {        if (string.IsNullOrEmpty(section))            throw new ArgumentException("Section 不能为空。", nameof(section));
                uint length = GetPrivateProfileSection(section, buffer, (uint)capacity, _filePath);
                if (length == 0)                    return new Dictionary<string, string>(StringComparer.OrdinalIgnoreCase);
                if (length < capacity - 2)                {                    return ParseSection(buffer.ToString());                }
                capacity *= 2;            }
            return new Dictionary<string, string>(StringComparer.OrdinalIgnoreCase);        }    }
    private Dictionary<string, string> ParseSection(string content)    {        Dictionary<string, string> result = new Dictionary<string, string>(StringComparer.OrdinalIgnoreCase);        string[] items = content.Split(new[] { '\0' }, StringSplitOptions.RemoveEmptyEntries);
        foreach (string item in items)        {            int index = item.IndexOf('=');
            if (index < 0)            {                result[item.Trim()] = string.Empty;                continue;            }
            string key = item.Substring(0, index).Trim();
            string value = item.Substring(index + 1);
            if (!string.IsNullOrEmpty(key))            {                result[key] = value;            }        }
        return result;    }    #endregion
    #region Delete    /// <summary>    /// 删除指定 Key。    /// </summary>    public void DeleteKey(string section, string key)    {        lock (_syncRoot)        {            bool result = WritePrivateProfileString(section, key, null, _filePath);
            if (!result)            {                throw new IOException("删除配置项失败:" + section + "/" + key);            }        }    }
    /// <summary>    /// 删除整个 Section。    /// </summary>    public void DeleteSection(string section)    {        lock (_syncRoot)        {            bool result = WritePrivateProfileString(section, null, null, _filePath);
            if (!result)            {                throw new IOException("删除 Section 失败:" + section);            }        }    }    #endregion
    #region Utility    /// <summary>    /// 判断指定 Key 是否存在。    /// </summary>    public bool ContainsKey(string section, string key)    {        string value = ReadString(section, key, null);
        return value != null;    }
    /// <summary>    /// 判断指定 Section 是否存在。    /// </summary>    public bool ContainsSection(string section)    {        return GetSections().Any(x => string.Equals(x, section, StringComparison.OrdinalIgnoreCase));    }    #endregion}
该文章在 2026/10/17 14:26:24 编辑过
