VB远程读取XML分支程序
2012年7月9日 1:28 本文热度 8945
以下保存为xml.xml文档,入在站点根目录下
<?xml version="1.0" encoding="gb2312"   ?>
<newdataset>
<allnum>3</allnum>
<workflow>
<title1>测试流程1</title1>
<Content1>allnum</Content1>
</workflow>
<workflow>
<title2>测试流程2</title2>
<Content2>如何用VB.NET编写XML文档[05-20] 浅析.NET下XML数据访问新机制</Content2>
</workflow>
<workflow>
<title3>测试流程3</title3>
<Content3>在本文的程序中使用到了一些"XmlNodeReader"的属性,譬如"NodeType"属性,用来判断读取得节点是什么类型。</Content3>
</workflow>
</newdataset>
以下新建一个VB工程,在对象窗体中加入三个Label,在代码窗体中加入以下代码:
Private Sub Form_Load()
XMLObject
End Sub
Private Sub XMLObject()
Dim WebURL As String, username As String, password As String
WebURL = "http://127.0.0.1/xml.xml"
Label1.Caption = "正在查询..."
Dim SendStr As String, XMLrandom As String, XMLObject, ReadFileText As String
Set XMLObject = CreateObject("Microsoft.XMLHTTP")
Randomize
XMLrandom = Rnd * Int((300 - 11 + 1) * Rnd + 11)
XMLObject.Open "GET", WebURL + "?&num=" + XMLrandom, False
XMLObject.setRequestHeader "CONTENT-TYPE", "application/x-www-form-urlencoded"
XMLObject.setRequestHeader "content-length", Len(SendStr)
XMLObject.send
ReadFileText = StrConv(XMLObject.ResponseBody, vbUnicode)
Label1.Caption = ReadFileText
Set XMLMorntekDocument = CreateObject("Microsoft.XMLDOM")
XMLMorntekDocument.Async = False
XMLMorntekDocument.ValidateOnParse = False
XMLMorntekDocument.Load (XMLObject.ResponseXML)
Label1.Caption = XMLMorntekDocument.selectSingleNode("//allnum").Text
Label2.Caption = XMLMorntekDocument.selectSingleNode("//title2").Text
Label3.Caption = XMLMorntekDocument.selectSingleNode("//Content2").Text
Set XMLMorntekDocument = Nothing
Set XMLObject = Nothing
End Sub
Private Sub Label2_Click()
End Sub
该文章在 2012/7/9 1:28:56 编辑过
