C# 数据类型与PostgreSQL 数据类型映射
maoxiaoming
2025年8月7日 8:55 本文热度 4529
Npgsql 是基于ADO.NET 的PostgreSQL 数据驱动。
Npgsql 官方 已经提供C# 数据类型与PostgreSQL数据类型的对应映射
地址: http://www.npgsql.org/doc/types.html
Type mappings
Type mappings when reading values sent from the backend
PostgreSQL typeDefault .NET typeProvider-specific typeOther .NET types
boolbool
int2short
byte, sbyte, int, long, float, double, decimal, string
int4int
byte, short, long, float, double, decimal, string
int8long
long, byte, short, int, float, double, decimal, string
float4float
double
float8double
numericdecimal
byte, short, int, long, float, double, string
moneydecimal
textstring
char[]
varcharstring
char[]
bpcharstring
char[]
citextstring
char[]
jsonstring
char[]
jsonbstring
char[]
xmlstring
char[]
pointNpgsqlPoint
string
lsegNpgsqlLSeg
string
pathNpgsqlPath
polygonNpgsqlPolygon
lineNpgsqlLine
string
circleNpgsqlCircle
string
boxNpgsqlBox
string
bit(1)bool
BitArray
bit(n)BitArray
varbitBitArray
hstoreIDictionary<string, string>
string
uuidGuid
string
cidrNpgsqlInet
string
inetIPAddressNpgsqlInetstring
macaddrPhysicalAddress
string
tsqueryNpgsqlTsQuery
tsvectorNpgsqlTsVector
dateDateTimeNpgsqlDate
intervalTimeSpanNpgsqlTimeSpan
timestampDateTimeNpgsqlDateTime
timestamptzDateTimeNpgsqlDateTimeDateTimeOffset
timeTimeSpan
timetzDateTimeOffset
DateTimeOffset, DateTime, TimeSpan
byteabyte[]
oiduint
xiduint
ciduint
oidvectoruint[]
namestring
char[]
(internal) charchar
geometry (PostGIS)PostgisGeometry
recordobject[]
composite typesT
range subtypesNpgsqlRange
enum typesTEnum
array typesArray (of child element type)
转自C# 数据类型与PostgreSQL 数据类型映射 - Pete-Jones - 博客园
该文章在 2025/8/7 8:55:49 编辑过
