SQL查询一张表的全部字段名称、类型、长度
2025年6月2日 8:50 本文热度 5955
:SQL查询一张表的全部字段名称、类型、长度
Oracle数据库:
SELECT column_name, data_type, data_length
FROM all_tab_columns
WHERE table_name = 'YOUR_TABLE_NAME'
ORDER BY column_id;
MySQL/MariaDB数据库:
SELECT COLUMN_NAME, DATA_TYPE, CHARACTER_MAXIMUM_LENGTH
FROM INFORMATION_SCHEMA.COLUMNS
WHERE TABLE_SCHEMA = 'YOUR_DATABASE_NAME'
AND TABLE_NAME = 'YOUR_TABLE_NAME';
SQL Server数据库:
WHERE TABLE_NAME = 'YOUR_TABLE_NAME';
PostgreSQL数据库:
SELECT column_name, data_type, character_maximum_length
FROM information_schema.columns
WHERE table_name = 'your_table_name';
DM(达梦)数据库:
SELECT atc.COLUMN_NAME, atc.DATA_TYPE, atc.DATA_LENGTH
FROM ALL_TAB_COLUMNS atc
WHERE atc.TABLE_NAME = 'YOUR_TABLE_NAME';
该文章在 2025/6/2 9:11:30 编辑过
