C#WinForm调用StiReport报表控件,实现打印模板格式自主设计、保存、预览、打印功能
2024年12月27日 21:43 本文热度 6053
下面给大家分享一套基于WinForm+StiReport的打印控件,可以实现自定义打印模板,数据源绑定、预览、保存、打印功能。
模板定义界面:
功能实现:
引用StiReport相关的dll:
项目生成:
部分代码展示:
        /// <summary>        /// 设计模板        /// </summary>        /// <param name="sender"></param>        /// <param name="e"></param>
       private void button1_Click(object sender, EventArgs e)        {            StiDesigner designer = new StiDesigner(report);            StiDesigner.SavingReport += StiDesigner_SavingReport;            report.RegData("TableVo", new WeightVo() { Code = "", Name = "" });            report.Compile();            report.Design();        }        /// <summary>        /// 保存模板        /// </summary>        /// <param name="sender"></param>        /// <param name="e"></param>
       private void StiDesigner_SavingReport(object sender, StiSavingObjectEventArgs e)        {
           // 获取项目输出目录的路径            string outputDirectory = AppDomain.CurrentDomain.BaseDirectory;            report.Save($"{outputDirectory}\\Report.mrt");            MessageBox.Show("保存成功!");        }        /// <summary>        /// 预览模板        /// </summary>        /// <param name="sender"></param>        /// <param name="e"></param>        private void button2_Click(object sender, EventArgs e)        {            // 获取项目输出目录的路径            string outputDirectory = AppDomain.CurrentDomain.BaseDirectory;            report.Load($"{outputDirectory}\\Report.mrt");            report.RegData("TableVo", new WeightVo() { Code = "001", Name = "这是一个打印测试模板" });            report.Compile();            report.Show();
       }        /// <summary>        /// 打印模板        /// </summary>        /// <param name="sender"></param>        /// <param name="e"></param>        private void button3_Click(object sender, EventArgs e)        {            // 获取项目输出目录的路径            string outputDirectory = AppDomain.CurrentDomain.BaseDirectory;            report.Load($"{outputDirectory}\\Report.mrt");            report.RegData("TableVo", new WeightVo() { Code = "001", Name = "这是一个打印测试模板" });            report.Compile();            report.Print();        }
阅读原文:https://mp.weixin.qq.com/s/qtFLtSITEQJvxi3Bf35tXw
该文章在 2024/12/28 12:07:01 编辑过
