asp使用AspJson转换json数据
2024年12月12日 17:7 本文热度 5370
需要使用json数据的场景很多,那么asp中如何操作json数据呢?asp与json格式又如何交互呢?本文介绍使用AspJson转换为json格式数据输出,以及解析json数据。
aspJSON1.17.asp文件
'Februari 2014 - Version 1.17 by Gerrit van Kuipers
Class aspJSON
    Public data
    Private p_JSONstring
    private aj_in_string, aj_in_escape, aj_i_tmp, aj_char_tmp, aj_s_tmp, aj_line_tmp, aj_line, aj_lines, aj_currentlevel, aj_currentkey, aj_currentvalue, aj_newlabel, aj_XmlHttp, aj_RegExp, aj_colonfound
    Private Sub Class_Initialize()
        Set data = Collection()
        Set aj_RegExp = new regexp
        aj_RegExp.Pattern = "\s{0,}(\S{1}[\s,\S]*\S{1})\s{0,}"
        aj_RegExp.Global = False
        aj_RegExp.IgnoreCase = True
        aj_RegExp.Multiline = True
    End Sub
    Private Sub Class_Terminate()
        Set data = Nothing
        Set aj_RegExp = Nothing
    End Sub
    Public Sub loadJSON(inputsource)
        inputsource = aj_MultilineTrim(inputsource)
        If Len(inputsource) = 0 Then Err.Raise 1, "loadJSON Error", "No data to load."
        select case Left(inputsource, 1)
            case "{", "["
            case else
                Set aj_XmlHttp = Server.CreateObject("Msxml2.ServerXMLHTTP")
                aj_XmlHttp.open "GET", inputsource, False
                aj_XmlHttp.setRequestHeader "Content-Type", "text/json"
                aj_XmlHttp.setRequestHeader "CharSet", "UTF-8"
                aj_XmlHttp.Send
                inputsource = aj_XmlHttp.responseText
                set aj_XmlHttp = Nothing
        end select
        p_JSONstring = CleanUpJSONstring(inputsource)
        aj_lines = Split(p_JSONstring, Chr(13) & Chr(10))
        Dim level(99)
        aj_currentlevel = 1
        Set level(aj_currentlevel) = data
        For Each aj_line In aj_lines
            aj_currentkey = ""
            aj_currentvalue = ""
            If Instr(aj_line, ":") > 0 Then
                aj_in_string = False
                aj_in_escape = False
                aj_colonfound = False
                For aj_i_tmp = 1 To Len(aj_line)
                    If aj_in_escape Then
                    Else
                        Select Case Mid(aj_line, aj_i_tmp, 1)
                            Case """"
                                aj_in_string = Not aj_in_string
                            Case ":"
                                If Not aj_in_escape And Not aj_in_string Then
                                    aj_currentkey = Left(aj_line, aj_i_tmp - 1)
                                    aj_currentvalue = Mid(aj_line, aj_i_tmp + 1)
                                    aj_colonfound = True
                                    Exit For
                                End If
                            Case "\"
                                aj_in_escape = True
                        End Select
                    End If
                Next
                if aj_colonfound then
                    aj_currentkey = aj_Strip(aj_JSONDecode(aj_currentkey), """")
                    If Not level(aj_currentlevel).exists(aj_currentkey) Then level(aj_currentlevel).Add aj_currentkey, ""
                end if
            End If
            If right(aj_line,1) = "{" Or right(aj_line,1) = "[" Then
                If Len(aj_currentkey) = 0 Then aj_currentkey = level(aj_currentlevel).Count
                Set level(aj_currentlevel).Item(aj_currentkey) = Collection()
                Set level(aj_currentlevel + 1) = level(aj_currentlevel).Item(aj_currentkey)
                aj_currentlevel = aj_currentlevel + 1
                aj_currentkey = ""
            ElseIf right(aj_line,1) = "}" Or right(aj_line,1) = "]" or right(aj_line,2) = "}," Or right(aj_line,2) = "]," Then
                aj_currentlevel = aj_currentlevel - 1
            ElseIf Len(Trim(aj_line)) > 0 Then
                if Len(aj_currentvalue) = 0 Then aj_currentvalue = aj_line
                aj_currentvalue = getJSONValue(aj_currentvalue)
                level(aj_currentlevel).Item(aj_currentkey) = aj_currentvalue
            End If
        Next
    End Sub
    Public Function Collection()
        set Collection = Server.CreateObject("Scripting.Dictionary")
    End Function
    Public Function AddToCollection(dictobj)
        if TypeName(dictobj) <> "Dictionary" then Err.Raise 1, "AddToCollection Error", "Not a collection."
        aj_newlabel = dictobj.Count
        dictobj.Add aj_newlabel, Collection()
        set AddToCollection = dictobj.item(aj_newlabel)
    end function
    Private Function CleanUpJSONstring(aj_originalstring)
        aj_originalstring = Replace(aj_originalstring, Chr(13) & Chr(10), "")
        aj_originalstring = Mid(aj_originalstring, 2, Len(aj_originalstring) - 2)
        aj_in_string = False : aj_in_escape = False : aj_s_tmp = ""
        For aj_i_tmp = 1 To Len(aj_originalstring)
            aj_char_tmp = Mid(aj_originalstring, aj_i_tmp, 1)
                aj_s_tmp = aj_s_tmp & aj_char_tmp
            Else
                Select Case aj_char_tmp
                    Case "\" : aj_s_tmp = aj_s_tmp & aj_char_tmp : aj_in_escape = True
                    Case """" : aj_s_tmp = aj_s_tmp & aj_char_tmp : aj_in_string = Not aj_in_string
                    Case "{", "["
                        aj_s_tmp = aj_s_tmp & aj_char_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10))
                    Case "}", "]"
                        aj_s_tmp = aj_s_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10)) & aj_char_tmp
                    Case "," : aj_s_tmp = aj_s_tmp & aj_char_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10))
                    Case Else : aj_s_tmp = aj_s_tmp & aj_char_tmp
                End Select
            End If
        Next
        CleanUpJSONstring = ""
        aj_s_tmp = split(aj_s_tmp, Chr(13) & Chr(10))
        For Each aj_line_tmp In aj_s_tmp
            aj_line_tmp = replace(replace(aj_line_tmp, chr(10), ""), chr(13), "")
            CleanUpJSONstring = CleanUpJSONstring & aj_Trim(aj_line_tmp) & Chr(13) & Chr(10)
        Next
    End Function
    Private Function getJSONValue(ByVal val)
        val = Trim(val)
        If Left(val,1) = ":"  Then val = Mid(val, 2)
        If Right(val,1) = "," Then val = Left(val, Len(val) - 1)
        val = Trim(val)
        Select Case val
            Case "true"  : getJSONValue = True
            Case "false" : getJSONValue = False
            Case "null" : getJSONValue = Null
            Case Else
                If (Instr(val, """") = 0) Then
                    If IsNumeric(val) Then
                        getJSONValue = CDbl(val)
                    Else
                        getJSONValue = val
                    End If
                Else
                    If Left(val,1) = """" Then val = Mid(val, 2)
                    If Right(val,1) = """" Then val = Left(val, Len(val) - 1)
                    getJSONValue = aj_JSONDecode(Trim(val))
                End If
        End Select
    End Function
    Private JSONoutput_level
    Public Function JSONoutput()
        dim wrap_dicttype, aj_label
        JSONoutput_level = 1
        wrap_dicttype = "[]"
        For Each aj_label In data
             If Not aj_IsInt(aj_label) Then wrap_dicttype = "{}"
        Next
        JSONoutput = Left(wrap_dicttype, 1) & Chr(13) & Chr(10) & GetDict(data) & Right(wrap_dicttype, 1)
    End Function
    Private Function GetDict(objDict)
        dim aj_item, aj_keyvals, aj_label, aj_dicttype
        For Each aj_item In objDict
            Select Case TypeName(objDict.Item(aj_item))
                Case "Dictionary"
                    GetDict = GetDict & Space(JSONoutput_level * 4)
                    aj_dicttype = "[]"
                    For Each aj_label In objDict.Item(aj_item).Keys
                         If Not aj_IsInt(aj_label) Then aj_dicttype = "{}"
                    Next
                    If aj_IsInt(aj_item) Then
                        GetDict = GetDict & (Left(aj_dicttype,1) & Chr(13) & Chr(10))
                    Else
                        GetDict = GetDict & ("""" & aj_JSONEncode(aj_item) & """" & ": " & Left(aj_dicttype,1) & Chr(13) & Chr(10))
                    End If
                    JSONoutput_level = JSONoutput_level + 1
                    aj_keyvals = objDict.Keys
                    GetDict = GetDict & (GetSubDict(objDict.Item(aj_item)) & Space(JSONoutput_level * 4) & Right(aj_dicttype,1) & aj_InlineIf(aj_item = aj_keyvals(objDict.Count - 1),"" , ",") & Chr(13) & Chr(10))
                Case Else
                    GetDict = GetDict & (Space(JSONoutput_level * 4) & aj_InlineIf(aj_IsInt(aj_item), "", """" & aj_JSONEncode(aj_item) & """: ") & WriteValue(objDict.Item(aj_item)) & aj_InlineIf(aj_item = aj_keyvals(objDict.Count - 1),"" , ",") & Chr(13) & Chr(10))
            End Select
        Next
    End Function
    Private Function aj_IsInt(val)
        aj_IsInt = (TypeName(val) = "Integer" Or TypeName(val) = "Long")
    End Function
    Private Function GetSubDict(objSubDict)
        GetSubDict = GetDict(objSubDict)
        JSONoutput_level= JSONoutput_level -1
    End Function
    Private Function WriteValue(ByVal val)
        Select Case TypeName(val)
            Case "Double", "Integer", "Long": WriteValue = val
            Case "Null"                     : WriteValue = "null"
            Case "Boolean"                  : WriteValue = aj_InlineIf(val, "true", "false")
            Case Else                       : WriteValue = """" & aj_JSONEncode(val) & """"
        End Select
    End Function
    Private Function aj_JSONEncode(ByVal val)
        val = Replace(val, "\", "\\")
        val = Replace(val, """", "\""")
        'val = Replace(val, "/", "\/")
        val = Replace(val, Chr(8), "\b")
        val = Replace(val, Chr(12), "\f")
        val = Replace(val, Chr(10), "\n")
        val = Replace(val, Chr(13), "\r")
        val = Replace(val, Chr(9), "\t")
        aj_JSONEncode = Trim(val)
    End Function
    Private Function aj_JSONDecode(ByVal val)
        val = Replace(val, "\""", """")
        val = Replace(val, "\\", "\")
        val = Replace(val, "\/", "/")
        val = Replace(val, "\b", Chr(8))
        val = Replace(val, "\f", Chr(12))
        val = Replace(val, "\n", Chr(10))
        val = Replace(val, "\r", Chr(13))
        val = Replace(val, "\t", Chr(9))
        aj_JSONDecode = Trim(val)
    End Function
    Private Function aj_InlineIf(condition, returntrue, returnfalse)
        If condition Then aj_InlineIf = returntrue Else aj_InlineIf = returnfalse
    End Function
    Private Function aj_Strip(ByVal val, stripper)
        If Left(val, 1) = stripper Then val = Mid(val, 2)
        If Right(val, 1) = stripper Then val = Left(val, Len(val) - 1)
        aj_Strip = val
    End Function
    Private Function aj_MultilineTrim(TextData)
        aj_MultilineTrim = aj_RegExp.Replace(TextData, "$1")
    End Function
    private function aj_Trim(val)
        aj_Trim = Trim(val)
        Do While Left(aj_Trim, 1) = Chr(9) : aj_Trim = Mid(aj_Trim, 2) : Loop
        Do While Right(aj_Trim, 1) = Chr(9) : aj_Trim = Left(aj_Trim, Len(aj_Trim) - 1) : Loop
        aj_Trim = Trim(aj_Trim)
    end function
End Class
示例一—输出json
<!--#include virtual="/aspJSON1.17.asp" -->
Set oJSON = New aspJSON
With oJSON.data
    .Add "familyName", "Smith"                      'Create value
    .Add "familyMembers", oJSON.Collection()
    With oJSON.data("familyMembers")
        .Add 0, oJSON.Collection()                  'Create object
        With .item(0)
            .Add "firstName", "John"
            .Add "age", 41
        End With
        .Add 1, oJSON.Collection()
        With .item(1)
            .Add "firstName", "Suzan"
            .Add "age", 38
            .Add "interests", oJSON.Collection()    'Create array
            With .item("interests")
                .Add 0, "Reading"
                .Add 1, "Tennis"
                .Add 2, "Painting"
            End With
        End With
        .Add 2, oJSON.Collection()
        With .item(2)
            .Add "firstName", "John Jr."
            .Add "age", 2.5
        End With
    End With
End With
Response.Write oJSON.JSONoutput()                   'Return json string
示例二—JS读取Json
前端js使用ajax调用后端接口,获取到上面的json数据,解析输出。
var postData="Action=Announce";
//alert(postData)
digtalMessage="";
digtalMessageAll="";
$.ajax({
   type: "GET",
   url: "/OKOA/CN/AjaxInfo.asp",
   data: postData,
   success: function(msg){
    //alert( "Data Saved: " + msg );
    var obj = jQuery.parseJSON(msg);
    $.each(obj,function(idx,item){
       //alert(item.activityBeginTime)
        digtalMessage=DigitalTime1(item.Title,item.Title,item.activityBeginTime,item.activityEndTime);
        digtalMessageAll=digtalMessageAll+" <a class=\"Default\" onClick=\"OpenWin('/OKOA/Announce.asp?ID="+item.ID+"','Annonce_"+item.ID+"')\" href=\"#\">"+digtalMessage+"</a>;"
    document.getElementById("LiveClock1").innerHTML=digtalMessageAll;
到此这篇关于asp使用AspJson转换json数据的文章就介绍到这了。
该文章在 2024/12/12 17:07:50 编辑过
