20 个 TypeScript 技巧改变你的代码!
2024年11月13日 19:35 本文热度 5460
TypeScript 以类型安全及强大特性强化了 JavaScript,然而众多开发者仅运用其基础功能。在此为您呈现一份涵盖 20 个高级 TypeScript 技巧的指南,这些技巧有助于提升生产力、代码可维护性,利于提高代码效率与可读性。每个技巧均佐以实用代码示例加以阐释。
1. NonNullable:剔除 null 与 undefined 类型
type User = { name: string; age?: number | null };
const userAge: NonNullable<User['age']> = 30; // No null or undefinedÏ
2. Partial:使所有属性变为可选属性
interface User {
  age: number;
  email: string;
const updateUser = (user: Partial<User>) => ({ ...user, updatedAt: new Date() });
updateUser({ name: 'John' });
3. Readonly:强制实现只读属性
const config: Readonly<{ apiUrl: string; retries: number }> = {
  apiUrl: 'https://api.com',
  retries: 5,
config.apiUrl = 'https://newapi.com'; // Error
4. Mapped Types:动态地转换现有类型
type Status = 'loading' | 'success' | 'error';
type ApiResponse<T> = { [K in Status]: T };
const response: ApiResponse<string> = { loading: 'Loading...', success: 'Done', error: 'Error' };
5. Optional Tuple Elements:使用变形 tuple 类型。
type UserTuple = [string, number?, boolean?];
const user1: UserTuple = ['Rob']; // Only name
6. Union Exhaustiveness:确保所有情况都被处理
type Status = 'open' | 'closed' | 'pending';
function handleStatus(status: Status) {
  switch (status) {
    case 'open':
      return 'Opened';
    case 'closed':
      return 'Closed';
    case 'pending':
      return 'Pending';
    default:
      const exhaustiveCheck: never = status;
      return exhaustiveCheck;
7. Omit:从类型中移除属性
interface Todo {
  title: string;
  description: string;
  completed: boolean;
type TodoPreview = Omit<Todo, 'description'>;
const todo: TodoPreview = { title: 'Learn TypeScript', completed: false };
8. Type Narrowing:使用 in 和 instanceof 来缩小类型
function processInput(input: string | number | { title: string }) {
  if (typeof input === 'string') return input.toUpperCase();
  if ('title' in input) return input.title.toUpperCase();
9. Conditional Types:应用条件逻辑
type IsString<T> = T extends string ? true : false;
type CheckString = IsString<'Hello'>; // true
10. 使用 as const 创建字面类型
const COLORS = ['red', 'green', 'blue'] as const;
type Color = (typeof COLORS)[number]; // 'red' | 'green' | 'blue'
11. Extract and Exclude:过滤联合类型
type T = 'a' | 'b' | 'c';
type OnlyAOrB = Extract<T, 'a' | 'b'>; // 'a' | 'b'
12. 自定义类型守卫
function isString(input: any): input is string {
  return typeof input === 'string';
13. Record:动态对象类型
type Role = 'admin' | 'user' | 'guest';
const permissions: Record<Role, string[]> = { admin: ['write'], user: ['read'], guest: ['view'] };
14. Index Signatures:添加动态属性
class DynamicObject {
  [key: string]: any;
const obj = new DynamicObject();
obj.name = 'Rob';
15. Never Type:用于详尽的检查
function assertNever(value: never): never {
  throw new Error(`Unexpected: ${value}`);
16. Optional Chaining:使用可选链
const user = { profile: { name: 'John' } };
const userName = user?.profile?.name; // 'John'
17. Null 合并操作符
const input: string | null = null;
const defaultValue = input ?? 'Default'; // 'Default'
18. ReturnType:推导函数返回类型。
function getUser() {
  return { name: 'John', age: 30 };
type UserReturn = ReturnType<typeof getUser>;
19. Generics:可变函数类型。
function identity<T>(value: T): T {
  return value;
identity<string>('Hello'); // 'Hello'
20. Intersection Types:组合多个类型。
type Admin = { privileges: string[] };
type User = { name: string };
type AdminUser = Admin & User;
这些技巧中的每一个都突出了编写更简洁、更可靠的 TypeScript 代码的方法。使用这些技巧,你可以充分利用 TypeScript 的完整类型系统,实现更安全、更易于维护的开发。
该文章在 2024/11/14 11:38:35 编辑过
