一个C#开发的、跨平台的解压缩的开源项
2024年1月22日 12:36 本文热度 5285
解压缩对于我们日常工作太经常用到了,毕竟它有诸多好处,比如节省空间、方便管理传输、保密作用等等。
而对于我们开发人员来说,项目开发也是经常需要用到,今天就给大家推荐用一个可以用于压缩、解压、解密,并支持多种压缩类型和格式的开源项目。
项目简介
这是一个纯C#压缩库,用于.NET Standard 2.0、2.1、.NET Core 3.1和.NET 5.0,支持格式有zip/tar/bzip2/gzip/lzip,功能实现有解压缩rar, 解压缩7zip, 解压缩zip, 解压缩tar解压缩bzip2, 解压缩gzip, 解压缩lzip。
项目结构
使用方法
压缩核心代码
protected void Write(CompressionType compressionType, string archive, string archiveToVerifyAgainst, Encoding encoding = null)        {using (Stream stream = File.OpenWrite(Path.Combine(SCRATCH2_FILES_PATH, archive)))            {                WriterOptions writerOptions = new WriterOptions(compressionType)                {                    LeaveStreamOpen = true,                };                writerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;using (var writer = WriterFactory.Open(stream, type, writerOptions))                {                    writer.WriteAll(ORIGINAL_FILES_PATH, "*", SearchOption.AllDirectories);                }            }            CompareArchivesByPath(Path.Combine(SCRATCH2_FILES_PATH, archive),               Path.Combine(TEST_ARCHIVES_PATH, archiveToVerifyAgainst));using (Stream stream = File.OpenRead(Path.Combine(SCRATCH2_FILES_PATH, archive)))            {                ReaderOptions readerOptions = new ReaderOptions();                readerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;using (var reader = ReaderFactory.Open(NonDisposingStream.Create(stream), readerOptions))                {                    reader.WriteAllToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions()                    {                        ExtractFullPath = true                    });                }            }            VerifyFiles();        }
解压核心代码
public abstract class ReaderTests : TestBase    {protected void Read(string testArchive, CompressionType expectedCompression, ReaderOptions options = null)        {            testArchive = Path.Combine(TEST_ARCHIVES_PATH, testArchive);            options = options ?? new ReaderOptions();            options.LeaveStreamOpen = true;            ReadImpl(testArchive, expectedCompression, options);            options.LeaveStreamOpen = false;            ReadImpl(testArchive, expectedCompression, options);            VerifyFiles();        }private void ReadImpl(string testArchive, CompressionType expectedCompression, ReaderOptions options)        {using (var file = File.OpenRead(testArchive))            {using (var protectedStream = NonDisposingStream.Create(new ForwardOnlyStream(file), throwOnDispose: true))                {using (var testStream = new TestStream(protectedStream))                    {using (var reader = ReaderFactory.Open(testStream, options))                        {                            UseReader(reader, expectedCompression);                            protectedStream.ThrowOnDispose = false;                            Assert.False(testStream.IsDisposed, "{nameof(testStream)} prematurely closed");                        }// Boolean XOR -- If the stream should be left open (true), then the stream should not be diposed (false)// and if the stream should be closed (false), then the stream should be disposed (true)var message = $"{nameof(options.LeaveStreamOpen)} is set to '{options.LeaveStreamOpen}', so {nameof(testStream.IsDisposed)} should be set to '{!testStream.IsDisposed}', but is set to {testStream.IsDisposed}";                        Assert.True(options.LeaveStreamOpen != testStream.IsDisposed, message);                    }                }            }        }public void UseReader(IReader reader, CompressionType expectedCompression)        {while (reader.MoveToNextEntry())            {if (!reader.Entry.IsDirectory)                {                    Assert.Equal(expectedCompression, reader.Entry.CompressionType);                    reader.WriteEntryToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions()                    {                        ExtractFullPath = true,                        Overwrite = true                    });                }            }        }    }
zip压缩用法
Write(CompressionType.None, "Zip.none.noEmptyDirs.zip", "Zip.none.noEmptyDirs.zip", Encoding.UTF8);
zip解压用法
Read("Zip.zipx", CompressionType.LZMA);
项目还未支持
  • RAR 5 解密
  • 7Zip 写入
  • Zip64  解压缩
  • 多卷Zip支持
项目地址:https://github.com/adamhathcock/sharpcompress
该文章在 2024/1/22 12:36:26 编辑过
