如何在C#中锁定文件夹
2024年1月9日 2:16 本文热度 4912
以下代码可以用来锁定和解锁文件夹,基本原理是在锁定时将目录的访问权限改为指定人员才有权限访问,解锁时将权限设置为所有用户都可以访问。
using System.IO;
using System.Security.AccessControl;
private void btnBrowse_Click(object sender, EventArgs e)
    if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
     // Select the folder to lock
     textBox1.Text = folderBrowserDialog1.SelectedPath;
private void btnLock_Click(object sender, EventArgs e)
    try
     string folderPath = textBox1.Text;
     string adminUserName = Environment.UserName;// getting your adminUserName
     DirectorySecurity ds = Directory.GetAccessControl(folderPath);
     FileSystemAccessRule fsa = new FileSystemAccessRule(adminUserName, FileSystemRights.FullControl, AccessControlType.Deny)
     ds.AddAccessRule(fsa);
     Directory.SetAccessControl(folderPath, ds);
     MessageBox.Show("Locked");
    catch (Exception ex)
     MessageBox.Show(ex.Message);
private void btnUnLock_Click(object sender, EventArgs e)
    try
    FileSystemAccessRule fsa = new FileSystemAccessRule(adminUserName,FileSystemRights.FullControl, AccessControlType.Deny)
    ds.RemoveAccessRule(fsa);
    MessageBox.Show("UnLocked");
该文章在 2024/1/9 2:19:49 编辑过
