【C#】IP地址限制访问本服务器
2021年8月2日 8:56 本文热度 9569
    string id = Request["id"];
    if (id != null && id == "574")
        string ip;
        try
            HttpRequest request = HttpContext.Current.Request;
            if (request.ServerVariables["HTTP_VIA"] != null)
                ip = request.ServerVariables["HTTP_X_FORWARDED_FOR"].ToString().Split(',')[0].Trim();
            else
                ip = request.UserHostAddress;
        catch (Exception e)
            throw e;
        char[] dot = new char[] { '.' };
        string[] ipArr = ip.Split(dot);
        if (ipArr.Length == 3)
            ip = ip + ".0";
        long ip_Int = 0;
        long p1 = long.Parse(ipArr[0]) * 256 * 256 * 256;
        long p2 = long.Parse(ipArr[1]) * 256 * 256;
        long p3 = long.Parse(ipArr[2]) * 256;
        long p4 = long.Parse(ipArr[3]);
        ip_Int = p1 + p2 + p3 + p4;
        bool ok = true;
        ////允许的IP地址范围:ipcheck
        string[,] ipcheck = new string[,] { { "210.47.0.1", "210.47.0.255" }, { "192.168.0.1", "192.168.255.255" } };
        for (int i = 0; i < ipcheck.GetLength(0); i++)
            long ipcheck0 = 0;
            ipArr = ipcheck[i, 0].Split(dot);
                ipcheck[i, 0] = ipcheck[i, 0] + ".0";
            ipcheck0 = p1 + p2 + p3 + p4;
            long ipcheck1 = 0;
            ipArr = ipcheck[i, 1].Split(dot);
                ipcheck[i, 0] = ipcheck[i, 1] + ".0";
            ipcheck1 = p1 + p2 + p3 + p4;
            if (ip_Int < ipcheck0 || ip_Int > ipcheck1)
                ok = false;
            else
                ok = true;
                break;
        if (!ok)
            Response.Write("您的ip不允许访问此内容");
            Response.End();
该文章在 2021/8/2 8:56:40 编辑过
