C#程序删除自身及所在目录
2021年7月1日 14:56 本文热度 8951
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
using System.Configuration;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace killself
    class Program
            BeginKillSelf();
        [DllImport("kernel32.dll")]
        public static extern uint WinExec(string lpCmdLine, uint uCmdShow);
        private static  void BeginKillSelf()
            string vBatFile = Path.GetDirectoryName(Application.ExecutablePath) + "\\a.bat";
            using (StreamWriter vStreamWriter = new StreamWriter(vBatFile, false, Encoding.Default))
                vStreamWriter.Write(string.Format(
                ":del\r\n" +
                " del \"{0}\"\r\n" +
                "if exist \"{0}\" goto del\r\n" +
                "del %0\r\n", Application.ExecutablePath));
            WinExec(vBatFile, 0);
            Process.GetCurrentProcess().Kill();
            Environment.Exit(0);
该文章在 2021/7/1 14:58:28 编辑过
