【C#】ASP.NET Web.Config 读写辅助类
2021年5月11日 17:59 本文热度 7529
using System;
using System.Configuration;
using System.Web;
using System.Web.Configuration;
namespace Whir.ezEIP
    /// WebConfig读写辅助类
    public class WebConfigManager : IDisposable
        private Configuration _config;
        /// WebConfig读写辅助类
        public WebConfigManager()
            : this(HttpContext.Current.Request.ApplicationPath)
        /// WebConfig读写辅助类
        public WebConfigManager(string path)
            _config = WebConfigurationManager.OpenWebConfiguration(path);
        #region IDisposable Members
        public void Dispose()
            if (_config != null)
                _config.Save();
        #endregion
        /// 设置应用程序配置节点,如果已经存在此节点,则会修改该节点的值,否则添加此节点
        /// 节点名称
        /// 节点值
        public void SetAppSetting(string key, string value)
            var appSetting = (AppSettingsSection)_config.GetSection("appSettings");
            if (appSetting.Settings[key] == null) //如果不存在此节点,则添加
                appSetting.Settings.Add(key, value);
            else //如果存在此节点,则修改
                appSetting.Settings[key].Value = value;
            Save();
        /// 设置数据库连接字符串节点,如果不存在此节点,则会添加此节点及对应的值,存在则修改
        /// 节点名称
        public void SetConnectionString(string key, string connectionString)
            var connectionSetting = (ConnectionStringsSection)_config.GetSection("connectionStrings");
            if (connectionSetting.ConnectionStrings[key] == null) //如果不存在此节点,则添加
                var connectionStringSettings = new ConnectionStringSettings(key, connectionString);
                connectionSetting.ConnectionStrings.Add(connectionStringSettings);
            else //如果存在此节点,则修改
                connectionSetting.ConnectionStrings[key].ConnectionString = connectionString;
            Save();
        /// 保存所作的修改
        public void Save()
            _config.Save();
            _config = null;
使用方法:
 var config = new WebConfigManager();
config.SetAppSetting("StrRegex", "");
读取AppSetting和ConnectionString:
string fileType=ConfigurationManager.AppSettings["FileType "];
string connectionString = ConfigurationManager.ConnectionStrings["AspNetStudyConnectionString1"].ConnectionString;
该文章在 2021/5/11 18:08:52 编辑过
