C# 大图片压缩算法,减少图片体积
2021年3月18日 11:7 本文热度 7339
声明:
图片压缩算法,不建议对小图片进行压缩,一般文件小于1m的,真心没必要压缩,
图片很小的,例如:几百KB的图片,有可能不会减少图片体积,反而压缩后更大,也很正常,
请大家合理使用,并不是,所有图片,越压缩越好!!!!!
上面是我对2M多的图片进行了测试,压缩质量设置了50,压缩到了800KB,放大和缩小和原图,几乎没有什么区别。
代码如下:
private void button3_Click(object sender, EventArgs e)
            using (OpenFileDialog ofd = new OpenFileDialog())
                ofd.Filter = "图片|*.jpg;*.png;*.gif;*.jpeg;*.bmp";
                if (ofd.ShowDialog() == DialogResult.OK)
                    using (FileStream file = new FileStream(ofd.FileName, FileMode.Open))
                        var img = CompressionImage(file, 50L);
                        MessageBox.Show(CreateImageFromBytes(AppDomain.CurrentDomain.BaseDirectory + @"\" + Guid.NewGuid().ToString(), img));
        public static Image BytesToImage(byte[] buffer)
            MemoryStream ms = new MemoryStream(buffer);
            Image image = System.Drawing.Image.FromStream(ms);
            return image;
        public static string CreateImageFromBytes(string fileName, byte[] buffer)
            string file = fileName;
            Image image = BytesToImage(buffer);
            ImageFormat format = image.RawFormat;
            if (format.Equals(ImageFormat.Jpeg))
                file += ".jpeg";
            else if (format.Equals(ImageFormat.Png))
                file += ".png";
            else if (format.Equals(ImageFormat.Bmp))
                file += ".bmp";
            else if (format.Equals(ImageFormat.Gif))
                file += ".gif";
            else if (format.Equals(ImageFormat.Icon))
                file += ".icon";
            System.IO.FileInfo info = new System.IO.FileInfo(file);
            System.IO.Directory.CreateDirectory(info.Directory.FullName);
            File.WriteAllBytes(file, buffer);
            return file;
        /// 圖片流
        /// 壓縮質量0-100之間 數值越大質量越高
        private byte[] CompressionImage(Stream fileStream, long quality)
            using (System.Drawing.Image img = System.Drawing.Image.FromStream(fileStream))
                using (Bitmap bitmap = new Bitmap(img))
                    ImageCodecInfo CodecInfo =  GetEncoder(img.RawFormat);
                    System.Drawing.Imaging.Encoder myEncoder = System.Drawing.Imaging.Encoder.Quality;
                    EncoderParameters myEncoderParameters = new EncoderParameters(1);
                    EncoderParameter myEncoderParameter = new EncoderParameter(myEncoder, quality);
                    myEncoderParameters.Param[0] = myEncoderParameter;
                    using (MemoryStream ms = new MemoryStream())
                        bitmap.Save(ms, CodecInfo, myEncoderParameters);
                        myEncoderParameters.Dispose();
                        myEncoderParameter.Dispose();
                        return ms.ToArray();
        private static ImageCodecInfo GetEncoder(ImageFormat format)
            ImageCodecInfo[] codecs = ImageCodecInfo.GetImageDecoders();
            foreach (ImageCodecInfo codec in codecs)
                if (codec.FormatID == format.Guid)
                { return codec; }
            return null;
该文章在 2021/3/18 11:09:27 编辑过
