C# 获取IIS站点及虚拟目录信息
2018年9月8日 18:18 本文热度 10485
using System;
using System.DirectoryServices;
using System.Collections.Generic;
using System.Text;
namespace ConsoleApplication1
    class Program
            DirectoryEntry rootEntry = new DirectoryEntry("IIS://localhost/w3svc");
            int siteID = 1;
            foreach (DirectoryEntry entry in rootEntry.Children)
                if (entry.SchemaClassName.Equals("IIsWebServer", StringComparison.OrdinalIgnoreCase))
                    Console.WriteLine("Name: {0}", entry.Name);
                    Console.WriteLine("Path: {0}", IISWorker.GetWebsitePhysicalPath(entry));
                    Console.WriteLine("ServerBindings: {0}", entry.Properties["ServerBindings"].Value);
                    Console.WriteLine();
                    DirectoryEntry virEntry = new DirectoryEntry(entry.Path + "/ROOT");
                    foreach (DirectoryEntry entryVirtual in virEntry.Children)
                        if (entryVirtual.SchemaClassName.Equals("IIsWebVirtualDir", StringComparison.OrdinalIgnoreCase))
                            Console.WriteLine("SchemaClassName: {0}", entryVirtual.SchemaClassName);
                            Console.WriteLine("Name: {0}", entryVirtual.Name);
                            Console.WriteLine("Path: {0}", entryVirtual.Properties["Path"].Value);
                    int ID = Convert.ToInt32(entry.Name);
                    if (ID >= siteID)
                        siteID = ID + 1;
    public class IISWorker
        /// <summary>
        /// 得到网站的物理路径
        /// </summary>
        /// <param name="rootEntry">网站节点</param>
        /// <returns></returns>
        public static string GetWebsitePhysicalPath(DirectoryEntry rootEntry)
            string physicalPath = "";
            foreach (DirectoryEntry childEntry in rootEntry.Children)
                if ((childEntry.SchemaClassName == "IIsWebVirtualDir") && (childEntry.Name.ToLower() == "root"))
                    if (childEntry.Properties["Path"].Value != null)
                        physicalPath = childEntry.Properties["Path"].Value.ToString();
                    else
                        physicalPath = "";
            return physicalPath;
该文章在 2018/9/8 18:18:54 编辑过
