C#二维码生成与读取
2018年9月8日 16:4
本文热度 10725
使用ZXing.dll,下载类库,添加引用即可。
命名空间:using ZXing;
生成二维码:
/// <summary>
/// 生成二维码图片
/// </summary>
/// <param name="strMessage">要生成二维码的字符串</param>
/// <param name="width">二维码图片宽度</param>
/// <param name="height">二维码图片高度</param>
/// <returns></returns>
private Bitmap GetQRCodeByZXingNet(String strMessage, Int32 width, Int32 height)
Bitmap result = null;
try
BarcodeWriter barCodeWriter = new BarcodeWriter();
barCodeWriter.Format = BarcodeFormat.QR_CODE;
barCodeWriter.Options.Hints.Add(EncodeHintType.CHARACTER_SET, "UTF-8");
barCodeWriter.Options.Hints.Add(EncodeHintType.ERROR_CORRECTION, ZXing.QrCode.Internal.ErrorCorrectionLevel.H);
barCodeWriter.Options.Height = height;
barCodeWriter.Options.Width = width;
barCodeWriter.Options.Margin = 0;
ZXing.Common.BitMatrix bm = barCodeWriter.Encode(strMessage);
result = barCodeWriter.Write(bm);
catch (Exception ex)
//异常输出
return result;
读取二维码:
/// 解码二维码
/// 待解码的二维码图片
/// 扫码结果
private string DecodeQrCode(Bitmap barcodeBitmap)
BarcodeReader reader = new BarcodeReader();
reader.Options.CharacterSet = "UTF-8";
var result = reader.Decode(barcodeBitmap);
return (result == null) ? null : result.Text;
该文章在 2018/9/8 16:05:49 编辑过
