C#操作IIS创建应用程序池出现异常:无效索引(Exception from HRESULT:0x80070585)
2018年9月8日 15:28
本文热度 11298
在使用C#操作IIS创建应用程序池出现异常:无效索引(Exception from HRESULT:0x80070585)
相关代码:
public static string CreateAppPool(string appPoolName, string frameworkVersion, string managedPipelineMode)
DirectoryEntry rootfolder = new DirectoryEntry("IIS://localhost/W3SVC/APPPOOLS");
try
DirectoryEntry appPool = rootfolder.Children.Add(appPoolName, "IIsApplicationPool");
if (appPool.Properties.Contains("AppPoolCommand"))
appPool.Properties["AppPoolCommand"][0] = "1";
if (appPool.Properties.Contains("ManagedRuntimeVersion"))
appPool.Properties["ManagedRuntimeVersion"][0] = "v4.0";
//以下代码在WindowsServer2008版本为6.0的系统上会出现异常:
//无效索引(Exception from HRESULT:0x80070585)
//if (appPool.Properties.Contains("AppPoolIdentityType"))
// appPool.Properties["AppPoolIdentityType"][0] = "4";
if (appPool.Properties.Contains("Enable32BitAppOnWin64"))
appPool.Properties["Enable32BitAppOnWin64"][0] = true;
appPool.CommitChanges();
return null;
catch (System.Exception ex)
LogToFile.Save(ex, "CreateAppPool");
return ex.Message;
将相关代码注释以后,未见对Web应用程序带来任何影响。
该文章在 2018/9/8 15:28:55 编辑过
